Spec me a system
31 Aug 2009
Hi peps,
Right thinking of getting a new system build together but not sure what to go for so am after a bit of input from the fourm.
Looking for whole system from psu up.
Only spec must be baisd around an Asus Rog board PSU must be modular and corsair and will be a gaming system.
All ideas welcome.
what's your budget, and by whole system do you mean monitor/keyboard/mouse/operating system ?
Sorry should have said what I am after spec for is as follows.
Case, Asus Rog board, Cpu, Cpu cooler, Ram, Psu which must be moduler and pref corsair, graph card, ssd op drive, hdd for other files.
All for around £1000 mark give or take £100.
Got a rough idea in my mind just after some other input.
This would be my gaming system my current system is going into the folding business.
Also should be fairly future prof.
what's the system likely to be used for.
to give you a rough idea, slightly over your 1k budget, depends on what you want as to whether you sacrifice the ssd for a better gfx card, if you don't plan to use sli then drop the psu to a 650/750 model.
without losing the ssd, changing the 560ti to a 570 raises the cost to £1,130.
Asus GeForce GTX 560Ti DirectCU II 1024MB GDDR5 PCI-Express Graphics Card £179.99(£149.99)
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail with FREE TrackMania 2 Canyon PC Game £173.99
(£144.99)
Asus Maximus IV Gene-Z Intel Z68 (Socket 1155) DDR3 Motherboard £144.98 (£120.82)
Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive £139.99 (£116.66)
Corsair Obsidian 650D Gaming Midi Tower - Black Corsair Obsidian 650D Gaming Midi Tower - Black £124.99 (£104.16)
Corsair Enthusiast Series TX850M High Performance 850W Modular Power Supply (CP-9020004-UK) £113.99 (£94.99)
Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) £59.99(£49.99)
Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD204UI) £55.99 (£46.66)
Antec Kúhler H2O 620 CPU Watercooler (Socket Intel LGA 775 / 1155 / 1156 / 1366 / AMD AM2 / AM3 / AM2+ / AM3+) £49.99 (£41.66)
Sub Total : £869.92
Shipping : £13.75
VAT : £176.73
Total : £1,060.40
(£144.99)
Ok thanks for that sounds nice anyone else care to spec me a simaler AMD system?
Sub Total : £869.92
Shipping : £13.75
VAT : £176.73
Total : £1,060.40
amd wise, as reaper mentioned are behind at the moment, waiting for their new release, but you'd be looking at something like :
processor wise :
AMD Phenom II X6 Six Core 1100T Black Edition 3.30GHz (Socket AM3)
motherboard
Asus Crosshair V Formula AMD 990FX
with everything else kept the same price is £1,148.41.
mp the gene is a matx board, it'll look tiny in the case you've chosen.
wasn't aware it was matx fowler tbh, but i'd be more concerned if it was a big mobo in a small case, leaves room or airflow etc, and the possibility of moving to a larger mobo in the future if needs be.
