- 21 Jun 2006
Could probably stretch to £400 if needed.
http://www.powerhouse-fitness.co.uk/bodymax-cf520-elite-folding-standard-olympic-bench.php
This one has a max weight of 270kg, I weigh 80kg and I'm benching around 80kg so it'd give me another ~100kg to play with.
I'd just like something sturdier / better built than the cheap V-Fit jobby I've got now really with the ability to add a lat pulldown.
I use the bench for quite a lot really, presses, flies, close grip, kickbacks etc then use the (small) space to the side for deadlifts, standing shoulder presses and so on.
you cannot add a lat pulldown onto that.
mate if you want a lat pulldown you will either need to get a power rack then attach it to that or get a standalone lat pull down from a reputable make.
i would not trust a lat pull down attached to a bench, i dont think it would be stable enough or strong enough if you start to lift some half decent weights.
these are the options anyway from that site
http://www.powerhouse-fitness.co.uk/marcy-md880-olympic-bench-with-squat-and-lat-pulldown.php
http://www.powerhouse-fitness.co.uk/marcy-power-10-bench-press-with-squat-and-lat-pulldown.php
http://www.powerhouse-fitness.co.uk/bodymax-cf660-lat-pulldown.php
tbh at that sort of money i would just go for
http://www.powerhouse-fitness.co.uk/deluxe-strength-package.php
but its £500 and sell all your old equipment, or sell it as scrap metal to a dealer.
the bench will be in there too along with my KB's. I need to sort out some equestrian matting and some mirrors too. There will be a refurbed rower, soft matting (for stretching & mobility work) and possibly a teathered bag if funds & space allow.
may well have to pick the front up and swing it in sideways!
