- 28 Mar 2005
- Newbury
So no anti cheat in this then?
Why would a co-op title require it?![]()
you can disable VAC from the ingame options..
me and a mate was playing this last night, after about an hour of getting the voice chat sorted so theres no echo from vent it played fine!
no one is forcing you to mod if you dont want to..
lets face it people shouldnt have to mod to get a decent FOV in the first place its obviously changeable and not hardcoded how long would it take the devs to add the option via a slider? 5 minutes?
What did you do to sort it out?
took about an hour of testing every method known to man, for me i just plugged in my old mic(that was pink jack) and set it to default device in windows and on steam then just turned the mic off.
for my mate(peroxlol) we spent ages trying since he dont have a spare mic lying around. in the end he downloaded a program called virtual audio cable, im at work atm so cant get a link, but its pretty easy, just install and then set that to default communication device and default device in windows and steam then mute it.
that should work!
Never played borderlands with randoms in coop?
God no. I played with friends up to max level. Some randoms can be a pita without ever needing cheats.
Even if I did join a game with random player that was cheating, it's not the world, I'd just quit that game and connect to another. It's not like they're causing problems for a server full of thirty other people.![]()
