- 10 Jun 2010
- Scotland
but what if he does?
atleast it will be there if he ever needs it.
a mild overclock with the stock cooler is doable something around 4GHz, wouldnt go past it personally.
Well if he does, then of course. However he did state he wouldn't and I'm sure he will know if he plans to or not. A lot of people avoid Xfire setups due to the problems. I personally prefer a single card and if I wanted to upgrade I would sell it and upgrade rather than adding another. Too power hungry also.
With regards to the stock cooler. They're garbage... however as you said, you can overclock with them a little. However to avoid your PC sounding like a jet engine and cooking itself. It's wise to spend 20 quid on a custom cooler to keep the noise and heat down, while allowing more headroom for big overclock.
If you get stuck when building (not sure if you've ever did a build before) Then just ask away... plenty of clever guys on these forums willing to help. Stulid, RJC and CMNDR_ANDI all spring to mind. Ignore the rest... they're wanabees HAHA! I joke of course!
