- 19 Dec 2010
- Berkshire
Guys
I have installed two 5870s, when running the Heaven benchmark then checking gpu z it says both gpus are under load, and i do have nearly double the frame rate so all good there.
When playing bad company 2 tough for an hour then checking gpu z the second gpu hasn't really done anything at all.
Things that are strange ( are they? ) gpuz says when clicking the first gpu that crossfire is enabled.
Second gpu it says its disabled
Should i be seeing the second gpu being used in BC2?
Thanks
Thanks
