So 9:18 is the target to hit. Running at 10mph would give me a 9 minute time. I know I can run at 12mph for 0.5 miles, so it might be achievable. Might have to give it a try.![]()
Those times are shocking, tbh. I was RMP and we had a fair bit of leeway with BPFA times - 10:30 was a "fail" (in as much as you could fail the BPFA). If a Para ran over 9 minutes, I'd be asking for his cap-badge.
IIRC we were given about 11mins to run 1.5mile in FFO (full fighting order, weighing 25lbs) back in the day.
I presume you are asking due to it being an army fitness test?
These times are for the fitness test, rather than the combat fitness test. Fitness is the press-up/sit-up/run, done PT gear. The combat test is the one done in fighting gear and has different times. 11 mins in greens is about right![]()
Marines?
edit: in case anyone didn't know, www.mapometer.co.uk is great for mapping out runs, it gives you elevation too.
To be fair, 1.5 mile times are dependant on where you do the run (treadmill, flat, hilly etc) and your age plays a factor.
True. My best in the last 12 months was <8:30 min on the road & flat. I'm 45
That said I don't train for that type of distance. Have had a bit of a break from running (about 8 months) but now back in the swing of things so only have a couple of recent 6min mile efforts to base my claims on![]()
