About to buy
Yes one is, I have that one plugged into my 6950, just not sure which 12v rail I plug the extra cable into. I think it is the 12v4 rail. This is the MANUAL and the pci-e cable has a green stripe.
Cool thanks. I have another query. Their is a 8 pin slot on my motherboard that is labeled ATX_12V_2X4, do I need to plug the 8 pin connector from my psu into it? The oy problem i see is that in my power supply manual the 8 pin connector is labelled as a 8 pin EPS12V, the 4 pin connector I have is the ATX12v
How is this looking
