- 20 Jul 2009
- Midlands
Hello
Today we have had a look at 4 of the best selling SSDs on the market, the Force 3 (performs the same as the Agility 3), the Vertex 3, the Crucial M4 (Firmware 0009) and the Kingston HyperX SSD.
To our suprise there was a clear cut winner offering the highest levels of performance where it counts. Take a look before and have a look as the results are quite suprising!!
A small thanks goes out to Bicepo for producing the screens for me for this!
AS SSD Read/Write Test
Force 3
HyperX
[FONT="]
[/FONT]
M4
[FONT="]
Vertex 3
[/FONT][FONT="]
[/FONT]Taking a look at these results shows the weakness of the Asynchronous NAND used in the Force 3. The results from the Synchronous NAND based drives (vertex 3 and HyperX) are near identical showing no difference bar the odd MB/s here and there which cant be put down to a performance benefit but more what was going on with the system at the time of benhing. The clear cut winner with a massive lead on the 4K-64Thrd is the Crucial M4 which is why a drive that on slower on paper in reality is faster showing the strengths of the Marvell controller over the Sandforce 2281 used on all 3 of the other drives.
[FONT="]
AS SSD IOPS Test
[/FONT][FONT="]
Force 3
[/FONT]
HyperX
[FONT="]
M4
[/FONT][FONT="]
Vertex 3
[/FONT][FONT="]
[/FONT]Looking over the IOPS shows an entirely different story. The Force 3 has been left to swallow the dust of the other Sandforce drives where the Vertex 3 just edges out the HyperX however once again the Crucial is storming a head of the competition by a considerable margin.
[FONT="]
ATTO
Force 3
[/FONT][FONT="]
HyperX
[/FONT][FONT="]
M4
[/FONT][FONT="]
Vertex 3
[/FONT][FONT="]
[/FONT]
Here we can see that the Force 3 is hot on the heals of the Vertex 3 and the HyperX. The HyperX through consistency is the faster of this benchmark in reads and writes leaving the M4 miles behind where write speeds are concerned. The only saving grace for the M4 is that its read speeds are faster lower down the scale which when real world performance is concerned would play to an advantage.
CrystalDiskMark
Force 3
[FONT="]
HyperX
[/FONT][FONT="]
M4
[/FONT][FONT="]
Vertex 3
[/FONT]
This is the benchmark that clearly shows the brute force power of the Sandforce 2281 controller. The fastest drive overall here is yet again the HyperX however once again the files that count (4K QD32) leaves the reads of the M4 striding miles in front! The drive is only let down by its poor write speeds (in comparrison) giving the HyperXC the edge.
Conclusion
The Fastest drive here in real world performance is the Crucial M4. It is worth noting that the M4 in 256GB and 512GB sizes performs even faster on the write speeds due to the NAND chip density.
As for Sandforce based drives it would appear that the HyperX has the edge. It is a worthy contender in the SSD market bettering the M4 in some situations but losing in others. Only the price point nearing £40inc VAT on top of the M4 is its only weakness. If Kingston can do something radical with the pricing and maintain fantastic quality construction of the drives then it may just have the raw grunt to knock the M4 off of top spot leaving it in top spot but as it stands the Crucial M4 just has it.
Corsair Force Series 3 120GB SATA 6Gb/s Solid State Drive (CSSD-F120GB3-BK) @ £139.99 inc VAT
Step up to SATA 6Gb/s performance with a Corsair Force Series 3 SSD. Your system responds better, boots quicker, and loads applications faster. Ideal for notebooks, Corsair SSDs run cooler and quieter than traditional hard drives, using less power.
- 120GB Capacity
- Sequential read speeds of up to 550 MB/s
- Sequential write speeds of up to 510 MB/s
- SATA 6Gb/s (SATA 3) connectivity
- High performance SandForce SF-2200 SSD controller
- Native TRIM support (O/S support required)
- RAID Support
- BGC (Background Garbage Collection)
- 2.5" - 3.5" Adaptor Included.
Only £139.99 inc VAT.
ORDER NOW
Kingston HyperX 120GB 2.5" SATA-3 Solid State Drive @ £188.99 inc VAT
The all new Kingston HyperX performance SSD featuring the Sandforce SF-2281 controller for blistering fast reads and writes and industry leading IOPS.
- 95k IOPS
- Capacity: 120GB
- Controller: SandForce SF-2281
- Maximum Read: 555MB/sec
- Maximum Write: 510MB/sec
- Max I/O Per Second (IOPS): 95000 IOPS (4KB File, READ)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Only £188.99 inc VAT.
ORDER NOW
OCZ Vertex 3 120GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-120G) @ £184.99 inc VAT
As the third generation of the legendary Vertex Series, OCZ Vertex3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Vertex3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Vertex3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.
Using the latest break through controller and flash technology, Vertex3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.
- Capacity: 120GB
- Maximum Read: 550MB/sec
- Maximum Write: 500MB/sec
- Sustained Write: 500MB/sec
- Max I/O Per Second (IOPS): 60000 IOPS (4KB File)
- 2.5" to 3.5" SSD adaptor included
- Warranty: 3 Years
Only £184.99 inc VAT.
ORDER NOW
Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive @ £134.99 inc VAT
Continuing the tradition of our award-winning solid-state drives, the Crucial m4 offers mobile and desktop users scorching-fast read and write speeds. Low power, lightweight, and durable, it empowers high-speed synchronous MLC NAND, advanced controller technology, optimized NAND management, and the SATA 6Gb/s interface. Together, that technology dramatically improves data transfers for bandwidth-demanding applications.
Our products are built on decades of design and manufacturing expertise. It is our expertise in NAND technology that enables us to optimize the performance and endurance necessary to build quality solid-state storage devices.
- Sequential Read (up to): 415MB/sec (SATA 6Gb/s) - 550MB/sec with firmware 0009
- Sequential Write (up to): 175MB/sec (SATA 6Gb/s) - 200MB/sec with firmware 0009
- Random 4k Read: 40,000 IOPS
- Random 4k Write: 35,000 IOPS
- PCMark Vantage: 55K HDD Test Score
- Interface: SATA 6Gbps / Backwards Compatible 3Gbps
- Seek Time: .1ms
- Slim 2.5" Design
- 100.5 x 69.85 x 9.5mm
- Lightweight: 75g
- Operating Temp: 0°C ~ 70°C
- Storage Temp: -40°C ~ 85°C
- Low Power Consumption: 150 mW in operation, .85 mW in standby
- Shock Resistant up to 1500G
- RAID Support
- MTBF: 1.2 million hours
- Limited 3-Year Warranty
** FIRMWARE UPDATE 0009 - Increased speeds up to 550MB/s **
Only £134.99 inc VAT.
ORDER NOW
Force 3
HyperX
[FONT="]
M4
[FONT="]
Vertex 3
[/FONT][FONT="]
[FONT="]
AS SSD IOPS Test
[/FONT][FONT="]
Force 3
HyperX
[FONT="]
M4
[/FONT][FONT="]
Vertex 3
[/FONT][FONT="]
[FONT="]
ATTO
Force 3
[/FONT][FONT="]
HyperX
[/FONT][FONT="]
M4
[/FONT][FONT="]
Vertex 3
[/FONT][FONT="]
CrystalDiskMark
Force 3
[FONT="]
HyperX
[/FONT][FONT="]
M4
[/FONT][FONT="]
Vertex 3
Conclusion
- 120GB Capacity
- RAID Support
ORDER NOW
- 95k IOPS
- Capacity: 120GB
- Warranty: 3 Years
ORDER NOW
- Capacity: 120GB
- Warranty: 3 Years
ORDER NOW
- Seek Time: .1ms
- Slim 2.5" Design
- Lightweight: 75g
- RAID Support
ORDER NOW
