My Coolermaster ATCS 110 is getting long in the tooth now, I've had it for over 10 years now and my Thermaltake TRUE is pushing right up against the side panel
I want to replace it with a similar sized case, currently 484H, 196W, 535D
Only need space for 3 hard drives max and 1 blu ray drive.
The ones I've found so far that I like are..
Coolermater Silencio
and the
Fractal Design Define R3
I like the sleek look of both and the fact that they don't have a window..
The Fractal has space for loads of 120mm fans, which is a plus. Whatever case I get, I'll be fitting it with Xilence Red Wing fans throughout and any rear 'finger protector' things will be cut out
Roughly £80 is my top limit, but it is a limit and not a target , any other cases I should look into?
	and the
