*** Official Dead Island Thread ***
How do I know whats a main and whats a side quest in this?
Are the main ones where we all go to the red circle and press B?
FAIL! now why would AVG think dead island is a threat?
I'll take a look but I'm at work - are they good stats?
You get them from the champagnen quest, you give some skank some champagne and she gives you diamonds :D
For the stats on the Developer mods, they are crap tbh the bat i got is for level 1 and crap stats. Its all about the mod on the weapon, it sends zombies flying and usually dying from smashing their faces into walls at ridiculous speeds lol.
As for the diamonds there is a place to get infinite amounts but i wont say unless you want a spoiler :p
CONFIRMED!!!!!!! NO VAC BAN!
The Steam Users' Forums points to a tweet from Steam Support replying to mund0x (someone explain how the latter is "verified" but the former isn't) following up on the recently raised question of whether modding Dead Island will earn someone a VAC ban from Steam. The simple question is: "can modding dead island get me vac banned?" The simpler answer is: "No." Thanks Acleacius.
Does that config tool let you change everything? Ot just set parameters. I just want to change FOV, increase shader to 2048 and max out everything
Shadow maps: You can now set the shadow map resolution to 512, 1024, 2048 or 4096
Field of view: Expanded selection of values ranging from 62.5 (default) to 90 degrees
Added an option to enable overcast weather
Added an option to enable vertical syncronization
Added an option to disable dust
Disabling bloom and weapon refraction now affects front30.ppfx and indoor30.ppfx
e.t.c
One thing that has bugged me with this game and its nothing even to do with the actual gameplay lol. How can this game have such a rotten title screen when it has an awesome soundtrack on all of its pre release trailers !!! Anyone else think this ??
I thought the uber bad ass backwards slowmo one was non-official/fanmade?
