- 29 Dec 2004
- Shepley
Should be similar to this:
http://forums.mtbr.com/drivetrain-s...bottom-bracket-service-guide-pics-497220.html
Looks about right, thanks mate.
I find them similar to my Shimanos. I wear a 10 shoe, and bought 11 in these and they fit well.
I have fairly narrow feet so took [DOD]Asprilla's advice on sizing.Welcome to Hoogerland shirt arrived last week, did anyone else get one?
awesome!
Edit: Oh, and to my disgust I just fitted some Crud RoadRacer MK2s to my roadie.![]()
Need a little advice, I'm currently riding a Hybrid but have decided it's time to get a road bike for next year to start doing longer distances (will still use the Hybrid during Winter months) but now seems to be a good time to buy with price reductions on the 2011 bikes before the 2012 models are available.
I've narrowed it down to 3:
Cannondale CAAD10 105
Giant TCR1
Forme Reflex
Compared to the Cannondale I can get the Giant for £100 less and the Forme for £100 more.
I definitely think the Cannondale is worth the extra over the Giant, but can't decide if I should go for the Carbon frame of the Forme rather than Aluminium? Are Carbon frames really that much more comfortable?
I did some research on the Forme bike and found out that the frames are made in Taiwan by the same company that makes Carbon frames for some of the top brands so quality sounds like it should be OK. My only other concern with the Forme are the One23 branded components which seemed lower quality and slighly heavier to me when compared to the equivalents on the other two bikes.
In winter I ride in:Any suggestions as to what I'd need in terms of jersey/leggings for the winter weather?
) previously, it seems to be only my hands that suffer in the cold. So much so that I wear two pairs of gloves when it's really cold. Otherwise, my winter gear is pretty much the same as Johnny69's. It has to be close to freezing before I'll break out the leggings, though.I would personally be happier getting a top flight alloy bike than a carbon bike I wasn't quite sure about (which it seems the Forme is to you).
Turns out this mountain bike I'm building has clearance for 700C wheels. The mudguard drillings are in fact caliper brake drillings. Damn. I could have saved myself a whole wad of $$$ and built a cross bike out of parts I already have here![]()
