How are you planning to cycle the tank?
Going to add a few hardy fish, danios, barbs or chorids, though not sure how many, the tank is 150l..
some articles suggest refreshing 10-15% of the water every few days..
Pictures don't really show off the tank too well, so many fish all moving about. They keep multiplying!
Started with 5 gupies and 2 platties
Needs to be watched at 480p![]()
Whether it was long enough or not, the ammonia, nitrite, ph etc were all fine and fish have been perfectly fine for about 2 months now.
So with the fishless cycling, you add ammonia and let the filter start to work?
How long after starting would you consider putting fishes in?
. I know its a pain and you need patience, but it does pay off in the long run, when you can add your full stock all at once![]()
Does anyone have a reedfish? I saw one the other day and thought it was fascinating.
imo goldfish should not be kept in tanks, they grow to big and really need a pond.
if you are getting a new tank i assume you are also getting a bigger filter (i reccomend a Fluval External Filter 305 for a 300L tank), place one of your new filter pads in with your current filter to try and seed it.
also use the water from your changes to fill the new tank and run the new filter with this water to seed the rest of the filter media.
it should help speed up the cycle process.
