hello all, i have an i5 2500k with an antec kuhler h2o 620 (with a second fan installed and running in push pull)
i get 56*c under full load in prime 95 @ 4.2ghz
i get 59*c under full load in prime 95 @ 4.4ghz
but if i try 4.6ghz @ 1.37v the bios accepts it and it passes the post, but when the 'windows is starting' screen should come up, it just sticks on a black screen.
I can only get it back by resetting the CMOS and setting up my clocks and stuff again (at 4.2 or 4.4)
i don't know if this has anything to do with it, but my hard drive setup is smart response enhanced mode.
Please help, before i installed the second fan and changed to push pull rather than exhaust, i was getting 68*c under full load @ 4.2ghz, so temperature should not be the issue. (i was expecting around 63*c @ 4.6 in push pull)
