- 28 Jul 2011
Does this game have a 2nd playthrough like Borderlands did then? i.e better items and monster level scaling?
I think its NG+ and some say its pretty much 2nd play through on borderlands
Is there anyway to play this game without connecting to steam? Or can I play it somehow on offline mode? My net is crap and it takes me an age to connect to steam.
This sucks, I would have never of ordered it if I knew it was an online game.
Damn my research skillz >.<
Read a few pages back, you need to set your join settings to none-single player.
While on the subject, anyone modding make sure to disable VAC.
You wont be VAC banned if you don't play with other VAC players, mod then play with players with VAC enabled and you could get a suspension.
Just what I picked up from the DI Mods page on the steam forums.
@freeman, sorry I miss-read your post, missed the part about steam being offline, in which case I'm not sure, have a google about or look on the steam forums, it should be possible as you can play the game totally SP.
Dear Customer,
thank you for your inquiry.
Because of the Steam "Cloud" architecture its actually only possible to play
Dead Island if the Steam Client is online and connected to the Steam network.
Our developers are working on a solution in order to make the "Offline Mode"
available for you. We're hoping for your understanding that we cant make any
promises at the actual moment.
Note: If you reply to this Email please do not edit the subject line. Thank
you!
Best regards
Your Support Team
Deep Silver Inc.
Technical Support
900 Larkspur Landing Circle
Larkspur CA 94939 / USA
- must have made about 100k each...
Only thing that sucks with these graphics tweaks is that one could get banned with VAC on, not likely but really isn't worth the chance. Only played the game with one buddy so far since he turns VAC off.
Nevertheless I'm almost 80% of the way through a second time lvl 41![]()
