AMD 7000 series details leaked
December is the earliest possible launch but its most likely gonna be January-February time.
Bulldozer we might see end of October if were lucky.
dammit! I was hoping they would be out for BF3...Looks like a couple of 6950s it is then.
Or have you fallen into Gibbo's trap ;)
nah just kidding, buy them up and sell your old stuff on MM for me :D
December for the high end or for any HD7000 series card?
Just that I assumed we were getting the low-end this month or next.
A 7950 that unlocks to a 7970 and a £100 quad core Bulldozer that unlocks to a octo core........ jawesome. The gpu, maybe, new architecture, the difference between a 6970/50 isn't massive in terms of shaders and the performance they give. The difference on the new gpu's, we'll have to see, it could be shader limited, or otherwise so it could make a small or big difference.
It will also be interesting to see the real difference between the top two gpu's, normally its about a 10% shader drop, its just under a 9% drop from 6970 to 6950, but due to the CU arrangement of the new architecture, its quite probably they'll disable one full Cu array, or 256shaders, if the real number for the 7970 is 2048, thats 1792 in the 7950, and closer to a 13% drop.
Thats all very much if's and buts, they might disable a smaller amount, the top card won't necessarily have 2048 shaders, etc, etc. Basically I can see the gap between a 7970/50 being either bigger this time, or the clock speed gap being smaller.
I feel like I'm dying inside, I just want a 7870 for BF3!
I have been looking though and even 5850's in crossfire beat a GTX 580 so I could always just get another 5830.
Given how many of us want one and the way these things go even the low to mid-range cards released at the first "launch" will probably be out of stock in five minutes. Rinse and repeat for the release of the high-end cards whenever they come out - thinking March/April 2012 :|.
More rumours to add to the fire.
Sounds good if true!
I like the memory frequency boost
So is the GNC architecture a brand spanking new architecture or just a tweak the previous generations? Enthusiasts and commentators have bemoaned that AMD have become to reliant on just tweaking the same architecture its had since the 2900 days.
