I felt myself really stupid.
If you didn't know, you didn't know, don't kick yourself over it, just rise above it
If you haven't already damaged the screw heads go out and buy the proper tools. Google these two screwdrivers as they're perfect for removing screws from water blocks:
Stanley FatMax XL 00 x 50mm Phillips Screwdriver
Wired--up T6 Torx Screwdriver
When will you get it back?
The price was reasonable , based on the manager's words. They spent 1 hour on my site and another 3 in their base. Totaly cost me 55 pounds + a free trip .
To begin with , I didnt ask them 2 fix my water cooling cause that will cost like 150 pounds.
What they did is replacement by installing CPU fan. The engineer who spent an hour on my site put everything 2gether ,even through the PC sparked!instead of booting. I felt so lucky as I virtually smelt the burning smell.
The guy brought back the PC and reinstalled for 3 hours by their engineers !(huge project,cuz they seldom dealt with a gaming machine)
This morning they gave me an unexpected reason as the RAM on board were overclocked which hardly made me 2 believe .They think the problem cause serious power issues.However ,I 'm so confused as the PC actually worked fine b4 moving the water block ,no way can I change the bios since I haven't powered the PC for a few days. I even don't know how exactly can I overclock the Rams. Strange :::::
Btw ,the PC works just perfectly now. The difference is not apparent between cooling methods. I should have chosen the air cooling in the first place.
3rd Removed because it was the same as the first
Theres the images
As Churchill the dog nods in the back ground "oh yeh" .....
I suggest you stay away from water cooling and sell me your kit . Ill allso have the dead DDC pump and ill buy it all off you.
Oh yeh as in its fixed .....
I should be getting a car soon so if i ever get some spare time and your free we can take a look at your kit, £50 for fitting a fan is a bit OTT though from that company. The guys that came out couldn't have been that good not to find a fault. There are a lot of cow boy IT companies around now a days and i deal with fixing there bad bodge jobs all the time.
£50 is a bargain to have a company come and fix it. Many would charge £30 call out, then £20 per hour.
These guys took it away and returned it working
