for catalyst 11.8 +cap
I spent hours and hours researching for a possible fix and found nothing other than "disable crossfire"
My issue was that bc2 was only using about 40% of each GPU which is clearly very poor and happens to be a very common problem
I tired every possible solution until I found someone said there was an issue with steam overlay, I disabled it but found no improvement.
I decided to install BC2 via Origin and believe it or not, it solved the problem, I knew it wasnt a hardware issue as other games ran perfectly well. With Origin my GPU usage is up to about 70-80% each, frame rate tops out at 120 with vsync most the time with everything on max and direct x 11
If anyone else has this problem plesae try this and let me know the results, hopefully this is the issue.
