OCZ vertex2 performance right?
3 Aug 2010
hi there, i don't really know what i should expect from my ssd lol so i thought i would ask you guys to see if this is right.
not to sure about this next one as i have no idea what the things on the left mean, and the write speed look poor to me for some reason.
so do these scores look about right? my motherboard is an asus formula 3 and i have a phenom 2 955@ 3.8ghz :D
Hi
No disrespect meant but... I'm assuming you realise that it's not good for these drives to do "too many" of these sorts of tests? Especially ones that writes lot of incompressible data to the drive.
IE. It can cause the drives to permanently throttle back!
Have a look at the OCZ forums if you want more info:
http://www.ocztechnologyforum.com/f...6-Vertex2-and-Agility2-support-and-discussion
For SandForce based drives ATTO is the best app. to test with. This is in fact what OCZ use to get the figures they quote in their literature.
Your AS SSD figures look a little low to me, but depends on how much use the drive has and how many times it's been bombarded with countless GB's of data from these sorts of test apps.
Mine from new looked like:
And before anyone else comments. Using the Microsoft AHCI drivers (as you are and me come to that) rather than the Intel RST ones, makes little real world difference in my experience.
Having had a closer look at your figures. While the reads look to be in the right ball park, the writes look low but that could be because of degradation from lots of writes. This should recover over time, unless you keep running these sorts of test apps and in that case, they will get even lower!
PS. I see you are not on the latest firmware (1.33 has been out for a while now).
PPS. I've been running version 1.33 on the firmware since it came out and with sleep/hibernate disabled (and drive set to never power down), I've had zero problems with it since last Oct/Nov. And it certainly gets hammered!!!
Hi, i've only ran the test like twice and they were my results on the first go :confused:
and is 1.33 the latest firmware? as i updated it to that yesterday with ocz toolbox (i think it worked anyway) but haven't yet done any tests on it and i also run with sleep/hibernate disabled
@mikeo are you using your SSD in a Dell Laptop? Is that the reason you disabled sleep/hibernate?
Nope...
There have been sleep/hibernate issues with the OCZ drives since they came out (see the large number of posts on the OCZ SandForce forum) and as not really interested in sleep/hibernate anyway (PC is on to use and switched off overnight when not in use) that's why it's been disabled. Though issues with resume from sleep/hibernate are not really just restricted to OCZ SSD's really, it's been a thorn in Windows side since it's day of inception! Though obviously aware that there are many (probably most these days) that have no issues in this area, as things are much improved since the "old days".
Just a precaution really, one of the things that the OCZ FAQ recommends (at least I'm assuming it still does). Not that I've had a problem, just being cautious.
Emmm... not sure what to suggested really.
I'm assuming you have it plugged into the first Intel SATA port?
I'd still be interested to see the results from ATTO though.
Mine:
And you will see that for compressible data (what ATTO tests with), that this gives the sort of figures that OCZ quote for their drives.
PS. I see you have a 60GB drive, but I would have thought that the performance figures should be pretty similar to the 120GB drive.
PPS. I'd check to see that the new firmware has been installed OK.
