- 29 Aug 2010
- Cornwall
Right so I'm in the process of rebuilding my watercooling system. again.
If I don't get it working as I want (cool and quiet) this time I'm giving up! (well, in theory)
Anyway, after I mentioned in one of rjkoneill's threads that I had been put of using coloured fluids in case it stained my blocks he seemed to get quite annoyed...
So I'm taking this to mean that coloured fluids wont stain blocks/radiators/reservoirs!
So I'm now wondering if I should go with my original idea of using coloured TFC tubing or if I should use the clear Masterkleer tubing and get some Mayhem dye (not the pre-mix)?
The Masterkleer tubing does seem more flexible, but I'm not sure if either tubing is better quality than the other.
I'm rebuilding the loop in a HAF 932 which will be sat under a desk, so it's not really gonna be visible except through the bay-res, but that has a blue LED anyway (I'd be getting blue dye)..
Thanks.
Thanks.
