I do not want to root the phone in case I balls it up and then can't return it to o2 if the GPS chip is just not working.
How about a forced firmware update? At the moment it is on an O2 firmware version - can I just update to a generic firmware (2.3.4 one) via Odin and avoiding rooting thus keeping warranty in tact!![]()
Ok so I picked up a SGS2 today and it is great apart from one thing....I can't seem to get the GPS to work. I have downloaded GPS tester and when the application starts nothing happens...no satellites are shown or anything.
On googlemaps my location can only be found when I enable wireless network positioning. I am guessing that this is a hardware problem so need to return the phone?
1 & 2 I take its just a different kernel?
My GPS normally takes more 30 seconds or more to get a proper fix normally.
Shame to hear that andyd.Just little things really, low in-call volume, low headphone volume, slow GPS lock, it feels a bit cheap and its a bit too big well for me anyway.
I am not saying its a bad phone, just not the right one for me.
Is there a way to increase the in call volume (from the phone speaker, not the loud speaker) on a non rooted phone? If not is this likely to be fixed in future firmwares?
I read something about a service mode but that needed doing each time the phone was restarted.
Other people can hear me fine but I can't her other people clearly if there is a lot of outside noise or the phone speaker is not exactly on my ear. Other people have reported this issue iirc so it is not a fault with my handset etc.
rp2000
any must have accessories ? has anyone bought the samsung sound horn ?
What is internet pass through? Tethering is built onto Android if that's what you mean.
I suppose the best way to describe would be as Reverse Tethering basically you can plug the Phone into the PC and use the PC's internet connection on the phone.
Its for use at work I dont have WIFI @ WorkCan't you just use WiFi?
Why wouldn't you just browse the web and download applications to the phone via the PC? xD
I have just ordered the white SGS2What is the current best cases?
I remember asking a while back (for my GF) and the response was the mesh one for quality/looks? Would the official mesh one contrast nicely or look wrong?
