- 8 Sep 2008
- Birmingham
Hi all
I recently bought a Corsair H100. When fitting it I noticed the backplate had some plastic attached to it. I cut this off with scissors, and it really didnt seem as if it was meant to come off.
Anyway, I seated the pump block on the cpu, did up the screws in the correct order, they were all as tight as possible and all seemed fine. I tested the temps using intel burn test and prime 95, each time the temp took 20 seconds to shoot past the 100 degrees C mark.
I took the cooler off and looked at the thermal compound. If the block was split into 8 sections, only the bottom 1st section actually made contact with the cpu (I could tell as the rest of the paste was untouched and looked like new).
Is this because I removed the plastic covering on the cpu backplate?
