so much for "if you can run BC2 max you will be fine for BF3"....
This has only ever really been stated by Dg, which I always said was BS.
I see there are servers up for a second map on the PC. Can I access and play this map?
Has anyone noticed that on - http://www.battlefield.com/battlefield3/1/beta - on the right hand side it says..
I SEE THERE ARE SERVERS UP FOR A SECOND MAP ON PC. CAN I ACCESS AND PLAY THIS MAP?
No. THIS MAP IS ONLY FOR INTERNAL BACK-END TESTS.
There's something seriously wrong with this game if they are going with Operation Metro Rush mode for the demo.
If you can wait, you may as well, just in case prices drop. Otherwise just do it
I ended upgrading during the alpha, but I was in desperate need of a new PC anyway so it had to happen then!
so where does the GTX460 stand?
my Mobo supports CF, so i could go ATI route.
Complete fail, joke of a map metro for 64 conquest, what was wrong with Caspian?
edit, lol it's 32 rush mode, even bigger fail.
A 560 is basically an overclocked 460 so you should be good for medium![]()
