SSD or 120Hz monitor?
31 May 2005
Nottingham
Which one to upgrade too?
My existing monitor is a 22". the size is fine, would just prefer a higher refresh rate.
Regarding the SSD, surely a boost from a traditional mechanical drive?
My opinion: the screen is your main point of interaction with a system, and fundamental to every task you will need to perform and experience you will have with your PC.
Hands down imo the monitor is what you should go for.
Depends what your doing.
If you do a lot of FPS gaming then a 120Hz panel is a must and one of the best is the 22" Samsung 2233RZ.
If your into more casual gaming and or spend a lot of time doing desktop stuff then you'd be better off with a nice high res IPS panel - as mentioned above you spend a lot of time interacting via the monitor so spending money there makes sense.
If you spend a lot of time doing desktop stuff then an SSD can help make things smoother and speed up application/game load times a little.
SSDs arent worth the money imo. Neither of the ones I have have impressed me.
Love my nice screens tho :p
SSD for me, without a doubt. Faster load times in and out of games make a huge difference. Example windows boot up is silly fast and RO being the first in for my choice of wep or MMO zoning. Got to be a big SSD tho, 120GB fills up mighty fast.
