SSD.
Much better than a mechanical drive, do you have SATA3.0 ports?
My opinion: the screen is your main point of interaction with a system, and fundamental to every task you will need to perform and experience you will have with your PC.
Hands down imo the monitor is what you should go for.
120hz monitor definitely if youre gaming
