Downloaded LinX as you said, tried to change problem size to 20000 and says "Not enough physical memory! Values corrected." and changes itself to 18725.
Stopped upon error after 10m 8s![]()
You will most likely need to up the vcore.
What is the CPU voltage under load?
You can check it in CPU-Z whilst running LinX.
Showing as 1.328V
Is that the max it gets to under load before it crashes?
I will check voltages on my other rig in a minute and let you know what you should set them to as a starting point.
Try setting CPU voltage to 1.4V and having another go. Sometimes those unlocked cores just need a bit of oompf to get them stable![]()
