- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys.
We now have stock of the new OcUK H2Flow Extreme cooler. This is the same pump/tubing and radiator as the Corsair H80. You just need to add your own fans (recommended 2) and your in for a chilly winter.
OcUK H²Flo Extreme Liquid CPU Cooler (Socket LGA1366/1155/1156/775/AM2/AM3) @ £59.99 inc VAT
The OcUK H²Flo EXTREME Liquid CPU Cooler is a fantastic product aimed at high end CPU cooling, with the power to slay any overclocked CPU temperatures succesfully. The cooler houses a large surface cold copper plate to ensure all the heat is drawn away from your CPU and transferred to the sealed liquid and the pump then transports the liquid round to the dual thick radiator which then cools the liquid back down to enable the liquid to recirculate back to your CPU block to again pull more heat away. All you need to do it add a fan of your choice to the radiator and your CPU will be cooler than the next Ice Age.
- Socket LGA1366 / 1155 / 1156 / 775 / AM2 / AM3
- Radiator Dimensions: 120mm x 152mm x 27mm
- Fan Support: 120mm x 38mm x 2
- Double-thick 120mm radiator for increased surface area and cooling potential
- A new improved micro-channel cold-plate design more efficiently transfers heat
- Quick and easy installation brackets make it easier than ever to upgrade to watercooling.
- Cold Plate: Copper
- Radiator Material: Aluminium
- Thermal paste is pre-applied
Only £59.99 inc VAT.
ORDER NOW
ORDER NOW
