Another OcUK Cooler in Stock!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys.
We now have stock of the new OcUK H2Flow Extreme cooler. This is the same pump/tubing and radiator as the Corsair H80. You just need to add your own fans (recommended 2) and your in for a chilly winter.
OcUK H²Flo Extreme Liquid CPU Cooler (Socket LGA1366/1155/1156/775/AM2/AM3) @ £59.99 inc VAT
The OcUK H²Flo EXTREME Liquid CPU Cooler is a fantastic product aimed at high end CPU cooling, with the power to slay any overclocked CPU temperatures succesfully. The cooler houses a large surface cold copper plate to ensure all the heat is drawn away from your CPU and transferred to the sealed liquid and the pump then transports the liquid round to the dual thick radiator which then cools the liquid back down to enable the liquid to recirculate back to your CPU block to again pull more heat away. All you need to do it add a fan of your choice to the radiator and your CPU will be cooler than the next Ice Age.
- Socket LGA1366 / 1155 / 1156 / 775 / AM2 / AM3
- Radiator Dimensions: 120mm x 152mm x 27mm
- Fan Support: 120mm x 38mm x 2
- Double-thick 120mm radiator for increased surface area and cooling potential
- A new improved micro-channel cold-plate design more efficiently transfers heat
- Quick and easy installation brackets make it easier than ever to upgrade to watercooling.
- Cold Plate: Copper
- Radiator Material: Aluminium
- Thermal paste is pre-applied
Only £59.99 inc VAT.
ORDER NOW
Depends on chip, if you are running AMD, next to nothing as H50 keeps the chip cucumber cool, if you are running 980x clocked to 4ghz + maybe 10 - 20%....
LP
Do the H100 240mm version for a reasonable price and I'm sold (would have to be less that you get the corsair though).
+1 i'd be very tempted too for a cheaper version of the H100
I wouldn't want the noisy original fan's, so they are no use to me. Mind you the H100 is around £80-90 so would would have to be a decent price on a variant to make it worthwhile.
One thing I'm glad of though is that OcUK is doing these kits at all... gives us guys another choice :-)
i agree, also no stock fans to drive the price up for no reason ;):p;)
OcUK would need to sell the 240mm cooler for around £64.99 to make it look competitive since you can get a Corsair H100 for £15 more than that.
