***Official*** Metro 2033 benchmark leaderboard
14 May 2011
Lincoln
A demanding game deserves a leaderboard so here it is.
There will be 4 leaderboards, DX11 Normal, DX11 Extreme, DX11 Ultra and DX10 Normal using the settings below, the benchmark app is located in the Metro 2033 install directory.
>> Leaderboard <<
DX11 Normal
DX11 Extreme
DX11 Ultra
DX10 Normal
Results will be posted in the format in my example in the following post.
DX11 Normal
Krony|i7 950 @ 4.2GHz|2x GTX 580 3Gb @ 772/2004|91.25fps
Need 2560x1600 resolution to show the dominating advantage of the 3GB vram :D
Get me a screenshot then of the app with that res selected and the same settings as the Extreme one and i'll add it as an Ultra.
Added a link to the spreadsheet in the OP, tried to embed it like the one on the Nvidia site here but can't seem to get it to work.
Normal
Krony|i7 950 @ 4.2GHz|2x GTX 580 3Gb @ 900/2025|98.54fps
Extreme
Krony|i7 950 @ 4.2GHz|2x GTX 580 3Gb @ 900/2025|52.47fps
This is where 3GB pwns 1.5GB :D
http://www.evga.com/forums/fb.ashx?m=1189095
Also, review from hardocp:
But I don't have a 30" monitor now so I cannot join that kind of extreme preset :mad:
Normal
Confused | Core i5-2500K @ 4.4 GHz | 4GB DDR3-12800 | Asus HD6850 1GB @ 850/1100 | 35.94 fps
Extreme
Confused | Core i5-2500K @ 4.4 GHz | 4GB DDR3-12800 | Asus HD6850 1GB @ 850/1100 | 15.77 fps
On these settings:
Quite disappointed really. Need to OC my card some more - Krony, what stable OC settings would you suggest? (If you don't mind)
Posted.
@Arcane, u need to use the settings shown in the templates in the OP and also the screenshot needs to show the date and the settings at the top.
@RobSmith, score does seem a tad low, try the 285.27 beta drivers, as for an overclock it's hard to just give u clocks my cards will run on as all cards are different but i would have thought on ur current voltage of 1.088v u could get it stable at 850 on the core, my old 580 SC used to run 24/7 on 850/2050 @ it's stock voltage of 1.088v and i think the max i got it to run stable was 962/2100 @ 1.15v but that was under water.
Edit: Added the preset for Ultra in the OP (had to photoshop it as i can't run that res :P)
I might also consider a DX10 leaderboard if i get enough interest.
Pushed a bit more and managed to break 100fps on the normal preset :)
Normal
Krony|i7 950 @ 4.2GHz|2x GTX 580 3Gb @ 940/2025|100.09fps
Extreme
Krony|i7 950 @ 4.2GHz|2x GTX 580 3Gb @ 940/2025|55.17fps
Normal
Krony|i7 950 @ 4.2GHz|2x GTX 580 3Gb @ 950/2050|102.06fps
Extreme
Krony|i7 950 @ 4.2GHz|2x GTX 580 3Gb @ 950/2050|56.45fps
Now at 880/2100 stable (1.1v) - I'm tempted to push it higher but I'm not sure if I should without after market cooler(?)
Normal
Extreme
