- 11 Jul 2004
- Neptune
The MP in this is cracking. Makes a change from the usual FPS and can be quite tactical.
Horde is a huge improvement over the last game![]()
I'm already a bit fed up of the MP in this game due to the ******* Sawn Off! I hate it with a passion. It's a proper noob gun. Just get near somebody,press fire and you get a kill. No aiming required.
The thing is, try it in versus bot match yourself, it requires being closer than you think and like the gnasher you are just aiming center screen. I find it much harder than the gnasher to get insta kills.![]()
It's got far more to give than the last one that's for sure. I never really enjoyed the last one after doing the 50 once. I think I've completed about 350 waves now.
Love it, it's pretty useless in public though because of the quitting.
I think to combat that you should be able to join games in progress if you like and be given a lump of money to spend depending on how much has already been earnt by the others.
Whats the quickest way to level up defences? Should I be buying multiple command posts and buying barriers or just buy the 1 command post and keep upgrading/maintaining the ones closest?
I ask because getting barriers from level 3 to level 4 took ages all because idiots kept buying everything they could all across the map and they never repaired them so they just went and wasted more money buying them again.
Video proof that the Sawn Off needs changing
Do you think they will patch the sawn off shotgun?
I hope so. They need to reduce the range if nothing else.Do you think they will patch the sawn off shotgun?
if they don't then I won't be buying any DLC for the game and i'll be trading it in for BF3 or MW3. This was my most wanted game this year but that gun has ruined MP for me.
