- 4 Apr 2003
My question is more based around your underlying assumption than anything else. We are already moving with the earth, yes? And when we fire a rocket into space, it continues to move in the same direction as the earth because of it's movement relative to the earth. If we time travel, do we retain our motion relative to the earth? If not, why not?
And sorry for digging at your spelling - that was cheap.
we may not know until we do it and test it out. unless time travel occurs within a closed system and we can full model and observe the mechanics on this, then it is reasonable to assume it is going to occur under both external and internal forces some of which will be observed and some of which we are not able to observe.
how do we know that universe/galaxy shift is not effecting the results measured with a neutrino, where they are are not just moving relative to the closed system cern believe they are measuring.
), but it is generally intended in the context of the model in question. Therefore, in this case if you assume the postulates of special relativity are true, then through a set of mathematical steps you can show FTL travel violates causality.
How can they go into the future and see what they come back with if as you say they cannot then travel back?
