GTX 580
They're not much of an upgrade from your GTX 480's.
i know but the spare pc is running GTX260 was going to sell both GTX480's get some 580's and up grade the other PC. hoping 300-400 for the 480's and i have 400 in OC vouchers :D
should cost me much i hope
No much point to upgrade from 480 SLI to 580 SLI unless you are going for the 3GB models for certain games or high resolution with high AA.
3GB will allow you to get higher playable settings under high resolution:
http://www.hardocp.com/article/2011/06/28/msi_n580gtx_lightning_xe_3gb_sli_video_card_review
So I would suggest you either hold for the upcoming 28nm cards, or just go for the 3GB 580s. There isn't really much point to "upgrade" to the 1.5GB 580s from 480 SLI.
any ideas on a release date for the 28nm cards ?
I've just gone from gtx 580 1.5gb to gtx 580 3gb so far it's added an extra fps and a few more points to my benchmarking scores that's it but I will be adding another one soon as I will be playing at 5760x1080 res...
would there be much performance between the
1536MB version or the 3072MB - going tobe running SLI
If you're running a large resolution with AA then yes. Also good for future proofing.
But if just running games at 1920x1080 then no.
3Gb, not 6Gb. In SLi the memory isn't doubled. I believe the data is duplicated between the cards.
So, then, what your saying is: 2x580's @ 3GB would only come out as 3GB and not 6GB?
If so, then what would 2x580 @ 1.5GB come out as? I take it not, 3GB then?.....I had the idea running in SLI you get double,....I'm confused, or badly miss-informed :(
sli 1.5Gb cards will give u a usable 1.5Gb of vram, in sli both cards have to store the same data so that's why it don't stack, the 590's only have 1.5Gb of usable vram too even tho they are specced as 3Gb.
Yes that is what i'm saying :) and 2 x 1.5Gb GTX 580s in SLi would give you 1.5Gb usable VRAM.
Cheers for clearing that up guys :) I have obviously been badly miss-informed
