You need rytilin.
lol
You need rytilin.
will I have had to buy something to play it?
Probably already been asked, but on Thursday, is the beta free to everyone, or will I have had to buy something to play it?
I've come to the opinion that Battlelog is crack, multiplay servers are poor (ho ho no surprise there so stop playing on them!), chat window needs sorting out, recon's sensor needs a boost to its range, and all that "be advised" rubbish needs to go.
Game itself is a BC2 + MOH + Brink merge. All the classes barely stand out from each other now that some weaponry is available cross classes (recon with a pp-2000?).
Hopefully better coordination comes with commo rose as the Q spamming is still bad (however good that it doesn't spot through bushes).
The best bit is the scrubs that moan camper. I can understand if it's spawn camping, however since it is rush... I hope no one here needs that explained to them.
I want to know what this surprise that is to come.
Its not unheard of! I'm getting 60FPS on max settings with VYSNC, Gameplay is smooth and truly enjoyable. Hope you get it resolved.
Hopefully the ability to join a server on the first attempt.
I mean on the Ultra setting
Although as stated I haven't seen any difference between low and ultra visually. The scenery and everything else looks more or less same at both settings
Some of you must be doing it all wrong. I have been happily playing tonight in a party of seven, joining and leaving servers as we please, all as a group and nobody getting disconnected or timed out.
That includes one Irish and two Poles. Even the ingame voip is working really well.
Trust me it doesn't, you need to set everythnig to low ingame then let the map reload into another game and you'll see the difference. or ideally, set everything to low, apply then quit out and join another server.
Would have been better if the visuals could change instantaneously, the moment we changed graphics settings
