AFAIK, you can't.Is it just my setup, Can anyone else bind their mouse?
i.e. Melee on mouse 3..ect...
Cheers
480 SLI oc here
Im at 2560x1600 res Ultra settings 4xmsaa 16xaf and what ever else turned on get average of 80 ish fps in the big open areas and 100 ish in the subway.
I'm not bragging, but I'm finding it incredibly easy to get kills on this. I don't know whether there isn't enough recoil, too much bullet damage, or what.
So far I have:
Kills 167
Deaths 66
K/D Ratio 2.53
If I do need a new PSU which is the best sort of value at OcUK at the moment?
Because if I do need one I'll come down tomorrow![]()
I know its a beta and all, and does look quite good at first glance - but is it me or are there quite a few texturing issues? I was watching someone else play and noticed quite often there seemed to be problems with seams between textures, poorly aligned textures, etc. and a lot of textures that could have done with depth i.e. brick work, stone walls, paving slabs, etc. looked quite flat and almost out of place.
So far I have:
Kills 167
Deaths 66
K/D Ratio 2.53
