Well if you would be do kind as to talk me through it I would be most appreciative.
I have tried:
Just plain using the buttons in the control section and it shows "unknown value" or something like that, and doesn't work
Using the assigned button as a "macro" in the razor software I.e. Button 5 = "c" for crouch (as key binds) and it doesn't work - despite the button press showing as a "c" in Word
Using the assigned button as a "key press" in the razor software I.e. Button 5 = "c" for crouch (as key binds) and it doesn't work - despite the button press showing as a "c" in Word
I even have issues with assigning more than 2 key binds, I select an action, click to assign - first two work fine - any more the xvreen just "locks" and I have to hit escape to go back a step on the option memu and no key is assigned
I'm using a razer Lachesis with the 1.10 drivers and 1.95 Firmware (checked and updated as the latest version)
If anyone that has managed to assign mouse buttons successfully can give me some suggestions they would be most welcome
Cheers
TB
