Battlefield 3 thread - Server details in opening post -
Status
Not open for further replies.
Does anyone else get random CTD with no error message or anything?
Seems to be a common issue with either the server or client randomly crashing (though if you're on a caspian server it's possible you're being kicked)
I found it happened repeatedly when i was trying to play in windowed mode, but that could have been coincidence.
Thanks for the reply mate, I've ony done the Metro map I think it is. So annoying as every time I'm doing well or get a good kill streak that is when it happens! As selfish as it sounds I'm glad I'm not alone.
When it crashes back out look in the bottom left as well and see what the message you get, it might say something like the connection timed out (which suggests it was the server, though i'm not certain is definitely is)
Didn't know that, thanks again will look when it happens next time :)
hope they do unlock caspian, only managed 10 mins,and i crashed the heli with the inverted controls!!!! is it just me.. when i try to map things to my mouse ie reload, prone it doesnt work? and the same with mouse movments for heli and stuff?
Oh question for you lot....
I turn motion blur off in the options, save changes, go back in to the options again and it says it's turned on? strange bug it seems as it's definitely turning it off but not registering the off in the menu?
AFAIK you have to restart the game for graphical changes to take effect.
I'm having major CPU heat issues with this beta, all other games run under 80c including Crysis 2 and Deus ex, but my CPU hits 95 in metro, very strange, I'm not going to play any more as I think it maybe the coding. Is anyone else seeing a temp jump?
Status
