Acer Aspire laptop backlight stopped working?
29 Aug 2011
UK
Hey guys,
Well a few days ago my backlight stopped working as I was using it, The screen was dark but if I shine light at it the screen is visble. It was hooked to an external monitor and everything is working fine.
The screen had some red on the laptop screen previously everytime I boote it up and became whiter.
I have read that it is either the inverter need replacig or the backlight bulb or more worse the monitor. How I identify which one need replacing?
cheers
17 Jul 2008
buy an inverter its not that its something else...!
is there a seperate bulb? i have taken a few appart only ever noticed two parts, screen and inverter..
OP
29 Aug 2011
UK
Wll I have opened it up and see the inverter under the screen, should I get another inverter?
hopefully the backlight will work?
OP
29 Aug 2011
UK
Might take a few weeks, although I just realised the mouse pad on it stopped working aswell, keyboard is fine though.
OP
29 Aug 2011
UK
I turned the Laptop on today and the backlight seems to be fully working??? its been like over 1 hour. wts goin on? any 1 know?
1 Feb 2003
Kent
knackered microswitch that turns the backlight on when you open the lid? or the contact for it?
they go quite often on the laptops i repair at work, if it's not those it's normal the screen itself. no idea on Acer's though.
OP
29 Aug 2011
UK
Im not too sure if my one has a microswitch where do you find it? I hope its the inverter though since I just bought it. The mousepad on it stopped functioning so could that indicate any problems?
1 Feb 2003
Kent
it's on the motherboard (well the usb daughterboard on the ones i repair) next the one of the hinges. you can see it after removing the panel above the keyboard.
if it's working when you push it the backlight will turn on and off.
OP
29 Aug 2011
UK
Thanks mate,I received the inverter today so hopefull will be opening it up soon.
16 May 2007
It might be worth searching for a tech / service manual on how to open just the bits you need rather than taking everything apart. Has worked for me for HP and Dell thus far
OP
29 Aug 2011
UK
Lol I already opened but found out the left side of the new has 6-pins and the connector in my laptop has 7-pins :( dammit got 2 send it back. I'll try and look into the backlight switch.
OP
29 Aug 2011
UK
Does any1 still know why the mouse pad malfuctioned right after when the backlight stopped working. surely something trigger it
