Wow not bad at all, scaling very well.
This is my current setup (a gtx 460 is on the way and soon enuff a quadcore/2gb extra ram)
E2180 @ 3.1GHZ
2GB RAM
4850 512mb, slightly OC'd.
Win 7 64 bit/latest ati preview drivers
And surprisingly I can run it at 1280*1024, everything set to low on a 32 player server and it is very playable, if I put the same settings in BC2 it will run worser although BC2 will look better I think the way they've implemented the scaling for older systems is very good.
Next step, see how high I can crank it up at a playable FPS.
So those worrying about they're setup need to chill, my PC was built over 3 years ago and can still play it smoothly.
Cheers ak22, I'll be using that method instead
Is this really supposed to be the next big thing graphically. I just tried my first 10 minutes on it on Metro and i think it looks pretty naff. I would go as far to say that Crysis 2 looked better
Seriously dissapointed especially after some of the amazing footage we have seen in various trailers.
I was expecting a "wow!" far cry or crysis moment.....
Can't join any games?
Just get stuck at "joining server".
Just downloaded the beta but everytime I click play it opens a browser which doesnt actully load anything :S Help !
I'd like to say two things to players of this game.
1)If your HUD says someone is spawning on you then if possible make it a safe place to for them to do so. In other words, if you can make space for other players in the area you are in then do so. Or stop running and find cover, don't go for the "over the top" charge into certain death if some is going to spawn on you.
2) TURN YOUR TORCHES OFF
Thank you
And what are your graphics options set to?
