- 6 Jul 2006
- co durham
Try disabling UPnP on your router, this fixed all connection issues for me.
With regards to the full screen issue, I also had this and it turned out that Teamviewer running in the background was causing the problem. Do you have Teamviewer installed? (It's a remote desktop application).
If so, exit it and you should be able to go full screen.
If not, close down other software running in the background as it may cause conflicts.
no Teamviewer but will try the others thanks
im more than happy on xfire with 6950's!
Really want to play conquest on CB because Metro is getting stale fast.
