Ive seen on my 480's vram usage at 1513 on both cards.
Doesn't quite work like that, at least as far as i know crossfire has the same limitation as SLI in this respect. If you have 2 cards with 1GB vram, you have 1gb vram that can be used, and that's it.
Well both sets of VRAM are used. It's just that the same stuff has to be mirrored on both cards so the cards can work together.
i5 2500k
6850
Both at stock settings.
I set my BF3 to Ultra last night on 1280x1024 (I need a new monitor) and it runs smooth. I didnt check the FPS, but it was easily playable. I could notice a slight difference from the reccomended settings (high).
I'd probably keep my settings at high though for a more consistent performance, but its nice to know it can handle Ultra!
So what the conclusion then with GPU performance hits?
VRAM? Crossfire? BETA? Drivers? Or its just another Crysis thats built for hardware to play this game after no-one cares anymore?
I'll test without Crossfire later tonight and see A) whether it runs well and B) whether it cures the big stutter. I'm inclined to think it's driver related as if it was VRAM surely the performance decrease would be more linear? I'm not sure how modern cards work but I can't imagine they start replacing certain bits of texture memory once loaded?
Core i5 750 @ 3.8GHz
Radeon 6950 2GB @ 880/1350MHz (got room to overclock this yet)
2560x1440, FOV set to 95, Settings on High, Vsync off.
I'm getting 35-40 fps at the moment, everything seems smoother than before for some reason.
vRAM usage went down from 1.75GB to 1.25GB too. I guess the game needs a restart after applying new settings.
Did you change your FOV to 90? I suggest you do that if you haven't already, thats how the game is meant to be played
Nope! How do I change the FOV?
