- 25 Sep 2011
- Cambs
hi guys
getting my small home file server up and running properly for its first time,
i ran into some issues.
The IDE hard drive will not boot if the jumper pins are on master, the bios wont recognise the hdd at all.
To get it to recognise and boot from the drive, i have to set the pins to slave.. which is all fine, in a way.
But now i want to install 3 more hard drives, i cant select them all as slaves.
i was going to use both the primary and secondary IDE controllers up, with two drives per controller.
ideally it was meant to be, OS drive MASTER, 3 data drives as SLAVE,
but since my master os drive is actually running on slave pins, how do i go around this?
and why dont it recognise it on master pins????
thanks
thanks
