Aren't current solar panels something like 75% efficient?
No. Not even if you're using the most expensive cutting edge panels, made from rare materials using a very expensive fabrication process. 20% in perfect conditions, maybe. If they're brand new.
Stuff like that will help. If you could buy a solar station for your home and install it ready for your electric car then each day it could store enough energy to charge the car at night.
A quick look at a website devoted to promoting solar power (i.e. any bias will be in favour of it) gives an average solar irradiance in Stoke-on-Trent of 2.7 KWh per day per square metre. I think that's probably rather generous, since you only get 1368W/m^2 at the
top of the atmosphere bang on the equator. But I'll go with 2.7KWh per day per square metre on the ground in S-o-T, because I'm going to bias this post in favour of solar power as much as possible, to prove at point.
I'll bias it in favour of solar power some more by assuming that you are rich enough for money to be irrelevant to you, so you buy the most efficient solar panels in existence.
I'll bias it in favour of solar power to a silly extent by pretending that the weather conditions are always,
every moment of every day, perfect for those solar panels.
So you generate 540Wh per day per square metre, in this example biased to a silly extent in favour of solar power.
So every square meter would, in this example biased in favour of solar power to a silly degree, provide enough electricity to drive the car about a mile and a half, which could probably be stretched to 2 miles by additional electricity generated by regenerative braking.
So if you want a full charge per day you'd need at least 150 square meters of solar panels, and that's biasing it in favour of solar power to a silly extent.
