They've been being produced for 6-8 weeks ... I don't think Europe will only be getting 1000 chips in the first shipment![]()
They will if the yields are poor.
Bunch up mate!They're jumping on the premade watercooling bandwagon.
BTW,the BIOS used was an old one. One of the chaps on XS who is a reviewer said he to retest his sample with a new BIOS.
Anyway,we will soon find out next week with reviews from well known sites.
Prob just start off with the quad and maybe then reinvest when the next revision appear with hopefully some more grunt.
i get 1.04 pts at 3.6ghz,![]()
Utter,utter crap...ZERO need to upgrade from a Phenom II Quad Core, as you wont notice any difference whatsoever![]()
These results are even worse though when you remember that they are from the CPU running at the 4.2Ghz level.
Clock for clock, IPC for IPC, they are looking slower than the Phenom II....
Neat trick that, after years of R&D and billions of dollars spent....
something wrong somewhere...
at 4.2ghz i get 1.24pts on a single core.4 real cores beats 2 'modules' that's all, looks like AMD have gone the quantity over quality route.
Not looking good for me, looks to worse than Phenom II in most things bar massivily multi-threaded software. I only really game so this is going to be no use to me, as games are only really making use of four cores, at least for the time being. This will probably end up being slower than Phenom II clock for clock.
I think you're wrong and that it'll be vastly faster in most games than deneb or thuban, even at stock clocks.
