Why not Intel?
2500K is a mighty fine CPU.
The more cores the better for me. 6 or 8 is better then 4 for me, even if they are individually slower
Why not Intel?
AMD in market position mistake shocker. Anyone would think this semiconductor business was hard or something![]()
I'm not calling it a mistake.
Why not Intel?
Isn't it that sync Z68 feature that uses the GPU?If you do lots of work that involve many threads, then depending on price, the bulldozer could be your choice.
My question is, how would a 2500k/2600k perform video encoding with Lucid Virtu using the IGP compared to a bulldozer thats missing the IGP?
Would the SBs still be the video encoding choice?
Except they've called it an 8 core, not a 4 core.
So no, thinking of it as a 4 core doing 8 threads isn't a good thing.
Well that's just marketing isn't it, 8 core obviously sounds a lot better than 4 core if you're doing your shopping in PC World.
8 core BD much closer resembles a quad core with a type of 'Hyperthreading on steroids' than it does a true 8 core.
If this is true then it doesn't mean AMD made a mistake...
B) The Bulldozer architecture is only going to get sweeter as more revisions generation are released.
B) does not help the user who parts cash for the first revision though
Lucid Virtu lets you use a Sandy Bridge IGP for things like QuickSync whilst using a separate GPU. So if you have a Z68 motherboard and a separate GPU you get to have an awesome gaming and number crunching machine (overclocking) and also a mean encoder (QuickSync).
But they're not 8 individual true cores if that's what you're getting it.
Also, a module isn't limited to two cores IIRC.
I think they should have called it a 4 core personally (Module = core). But it's not, and so thinking of it as a quad core is weird.
It is a bit of a reversal for AMD. Remember all the original marketing from AMD that they had the only true quad core design, whereas Intel just stuck 2 dual cores together to make quad core Kentsfield. Trouble for AMD was, Intel's approach actually worked very well indeed. Now AMD themselves don't seem to have "true" 6 core and 8 core designs anymore with Bulldozer.
Yeah, they've basically made an 8 core consisting of 4 dual cores.
But they aren't even true dual cores either, they've been cut down into some kind of single/dual core hybrid.
