***** The Official Fifa 12 Thread *****
Just got this game haven't played fifa in years! I think i've got the defending okish using the containing method.
BUt how about attacking is best to go down the wings and cross it in? Or build it up slowly?
Also any tips for corner kicks ?
It depends on your style and team. I like to go down the wings and cross more often then not but like to have decent CMs so I have the option to go down the middle every now and again
if your crossing it in all the time you need someone at least 6 foot tall as your target man. i loved dzeko and ibra in the last game (scored headers for fun).
corners you need to aim for just outside the 6 yard box i find is the best place. just far enough for the keeper not to come but close enough that anything that connects is usually a goal. also use a player with the highest free kick accuracy then the highest power then the highest curve. try and add a little curve to the ball but not too much, this usually means that defenders misjudge the flight path but your strikers don't. corners are hard to master, a lot of it is luck due to the timing of runs, but a lot depends on the quality of the taker.
try not to choose taller players to take the corner either if their is a smaller player just as good.
I so need hulk, i just spent a fiver on packs and the best player i got was Kameni and Nzogbia...so annoying..
Ill add you in 5 mins if you want a game?
I had to spend £15 before I got Hulk.
My family is streaming stuff on pc so probably not a good time to play me as the match might be a bit laggy. When I see you on, I'll send you a message. :)
Which players should I look into buying to make profit? I'm guessing buying players from the EPL is the best way?
Any help will be appreciated.
lol TimBrad gg, that 3rd lob goal of mine may well have been the slowest goal ever! Thought I should have had a couple more but you had a good few close calls!
That all seems fairly obvious. Is a slow build up passing around and drawing their players out of position a good tactic?
also what skills tend to be good to beat players on the wings? Any Inscructions on how to do them as well would be dam handy as well:p
I got IF Marchisio in a pack but he's only worth 20k-ish. Tempted to just sell all the players I have at the moment and wait for prices to stabilise, they're mad at the moment.
Hammering the trading at the mo, sticking to Serie A. If I pretend I'm buying players for a particular team I find I get some bargains.
Playing some games against a mate earlier I've decided I like Lazio and 4-2-3-1. That to me has:
CDM: Rossi
CDM: Cambiasso
CAM: Hamsik
CAM: Hernanes
CAM: Zarate? Cisse?
But the rest of the team I'm unsure on. Halps?
So you're complaining because you can't break down a defence? It's not as if the CPU is controlling the entire opposition team, like they do when people play as the goalkeeper.
No, im not complaining that I cant break down a defence.
Im complaining that if im playing online then I should be playing a person and not a hybrid computer/player.
