Why?
because i want to test it out myself
Touché
Interjection
touché
(fencing) An acknowledgement of a hit.
An acknowledgement of the success, appropriateness or superiority of an argument or discussion; sometimes used sarcastically to mock one's opponent's absurd logic.
Student loan is in so i'm good to go. Ball's in your court AMD - but then there aren't even any BD mITX motherboards yet so I might be forced to go SB.
as i said i want to test it out myself and if it's crap i'd send it backDon't shoot the messenger! Why not wait for a few independent reviews before ordering? Not like you haven't waited long enough already
why!!!That's sort of dishonest somehow...
http://www.xtremesystems.org/forums...nally-tested&p=4969164&viewfull=1#post4969164Actually, we already have such an issue known for Bulldozer, and NO bench-marked system has the patch installed!
The shared L1 cache is causing cross invalidations across threads so that the prefetch data is incorrect in too many cases and data must be fetched again. The fix is a "simple" memory alignment and (possible)tagging system in the kernel of Windows/Linux.
I reviewed the code for the Linux patch and was astonished by just how little I know of the Linux kernel... lol! In any event, it could easily cost 10% in terms of single threaded performance, possibly more than double that in multi-threaded loads on the same module due to the increased contention and randomness of accesses.
Not sure if ordained reviewers have been given access to the MS patch, but I'd imagine (and hope) so! Last I saw, the Linux kernel patch was still being worked on by AMD (publicly) and Linus was showing some distaste for the method used to address the issue. One comment questioned the performance cost but had received no replies... but you don't go re-working kernel memory mapping for anything less than 5-10%... just not worth it!
why!!!
thats what the 7days are for
Any ideas if BDs will work on my board?
http://www.overclockers.co.uk/showproduct.php?prodid=MB-460-AS
What happens to the returned CPU? Is it sold as an OEM without the retail packaging?
I wouldn't want to purchase a CPU which has been tested to see how far it overclocks.
it's not about ocing every returnWhat happens to the returned CPU? Is it sold as an OEM without the retail packaging?
It looks there supposedly is an issue with prefetch and AMD is working on a patch:
Edit!!
Final8y posted this already!!
Seeing as i know your looking closely over there i will leave any more to you.
A 10% to 20% performance hit is quite large!! I wonder if the leaked AMD slides last week were for patched systems??
The Windows 8 schedulers are also meant to have upto 10% improvement in games too.
