Caporegime
- 7 Apr 2008
- Lorville - Hurston
I will make a new thread in regards to BSOD i recieved from RO2 and now BF3 beta just this evening. here is some info about the crash using "whoCrashed" app Resplendence Software - WhoCrashed, automatic crash dump analyzer
BF3 crashes:
RO2 crashes:
both crashes from ro2 and bf3 seems to be the same? any idea what they mean?
Specs:
• ASUS P6T deluxe Socket 1336 Mobo
• 6GB DDR3 Ram
• Nvidia 480GTX card
• Intel i7 920 2.6GHZ Nehalem
• Corsair 800W PSU
• Lian LI full tower PC-A7010 case
• Thermalright Ultra Extreme aka TRUE
• OCZ 120GB SSD
• PLus 5 SATA hdd's of different sizes and makes.
BF3 crashes:
[FONT=Segoe UI, Arial]On Sun 09/10/2011 20:44:54 GMT your computer crashed
crash dump file: C:\Windows\Minidump\100911-11856-01.dmp
This was probably caused by the following module: [FONT=Segoe UI, Arial]ntoskrnl.exe[/FONT] (nt+0x4B16CC)
Bugcheck code: 0x124 (0x0, 0xFFFFFA8005CE98F8, 0x0, 0x0)
Error: [FONT=Segoe UI, Arial]WHEA_UNCORRECTABLE_ERROR[/FONT]
file path: C:\Windows\system32\ntoskrnl.exe
product: [FONT=Segoe UI, Arial]Microsoft® Windows® Operating System[/FONT]
company: [FONT=Segoe UI, Arial]Microsoft Corporation[/FONT]
description: NT Kernel & System
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
[/FONT]
[FONT=Segoe UI, Arial]On Sun 09/10/2011 20:04:23 GMT your computer crashed
crash dump file: C:\Windows\Minidump\100911-13369-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA8005CCA8F8, 0x0, 0x0)
[/FONT]
RO2 crashes:
[/FONT]
[/FONT]
Specs:
• 6GB DDR3 Ram
• Corsair 800W PSU
• OCZ 120GB SSD
