- 30 Sep 2009
- Merseyside. UK
Me and my clanmates have been playing it for a while, great fun with 8 players
supcom forged alliance with the Blackops Unleashed mod (version 5 now i think) coupled with Sorian A.I and for matches that are painless to get set up use Tunngle
You can get Sorian & Blackops from the vault on GPGnet if need be but it's unreliable also here's one of the most common map packs as well
Black Ops Unleashed - http://forums.gaspowered.com/viewtopic.php?t=31172
Probably THE best possible mod you can get for supcom, many changes and improvments and unit adittions. try it yourself, it comes in several parts but they arent neccecary to play beyond having the main mod. but if you can get them all. Here's a video showng some of the new additions.
Sorian A.I - http://code.google.com/p/sorian-ai-mod/downloads/detail?name=Sorian_AI_Mod_2.1.1.exe&can=2&q=
Far far smarter than the default AI that comes with the game. Will give even battle hardened vetterans a run for their money.
Map Packs - http://forums.gaspowered.com/viewto...//forums.gaspowered.com/viewtopic.php?t=33841
A good selection of maps of all sizes.
Tunngle - http://www.tunngle.net/index.php?l=en
Superb P2P tool for connectiong with many games, very good due to low rescource use (unlike gpgnet) Sign up and go to the supcom room and join an existing game there or make your own.
oh one last thing, most of the players now use an unofficial patch which fixes a lot of the remaining bugs that the developer never bothered to sort out. You can grab that here.
http://supremecommander.filefront.com/file/FA_Patch_3603;102949
The main reason you will need this patch is if you dont use it (90% of the ppl i have played against via Tunngle do use it) you will get a desync box that keeps popping up and basicly ruins the game if you are not on the same patch.
Hope this helps and good hunting
