Unless the address of that debit card is in the US, then no.
Point of using entropay.com is so you can use a virtual CC and type in any old US address to satisfy Amazons region restriction.
Yeah, i was meaning can i use a debit card with entropay?
Lol can you not wait 3 days?
I won't get the physical warfare map pack if ordering from amazon though.
Not sure! Already have it ordered though, I won't get the physical warfare map pack if ordering from * though.
That site (UK version) is also offering the Specact Kit, which seems to be 8 additional character skins.
i am so ****ed right now, just found out DICE is taking out VOIP from the game and como rose is with first patch.
WT!
That's the one I'm going for as the physical warfare weapons pack are just items I can unlock over time whereas the specact kit will most likely cost 3 or 4 quid.
Plus it means I can have 2 of each class loadout from the get go.
Do you get the maps (Karkand etc) with this? Just making sure I'm reading the description correctly on the site.
No pretty sure it's CC only.
I ordered it yeah. Judging by this thread all you do is take the key and place on Origin. If it doesn't work, Amazon are good for refunds.
http://www.cheapassgamer.com/forums/showthread.php?t=298402
I doubt EA care that much, they simply aren't going to reveal the keys to UK people until the 28th, but should you have a key before then they'll likely accept it.
did i miss something or was ther no 'rear view' key in the BETA?
'V' didnt work for me! Bit daft if you cant check your 6!...
