Can some help me please with the Nixie clocks, the guide says and i quote
"Output 12V DC
Minimum power output capability of 250 mA"
My 12v power supply reads
"Output 12v 2.0A"
Is this too many amps for my nixie clock circuit, the guide says "minimum" 0.25mA so does it matter if im putting more amperage through the circuit but the volts are correct at 12.
Dammit should have listened better at uni in our electronics labs as part of my product design course , doh !![]()
Can you just use a dc-dc converter like this one HIGH Efficiency 100W 15A DC-DC power supply module and connect as much fans as you like.
how much has that thing cost you?
Oh i dunno what im doing wrong with this nixie clock.. appeared to have 5V then when i got to the next test which is the test and setting of 170v my 5v test point now reads ~1.62v and the 170v test point reads 2.6v
the adjustable screw on the 1k petentiometer doesnt affect the voltage what so ever!
Is there a good way to test which component might be causing this crazyness!!??
Check the fuse
