Really, anyone who has an ounce of common sense would know that the Bulldozer architecture is solid, and future revisions and die shrinks will show that. A patchy launch was almost inevitable for this kind of design, when you take all things into account.
From what i've heard piledriver will still be up to 8 cores, with a 3-5% ipc improvement and a 7-10% clock speed improvement, as well as lower power consumption across all uses. Combine that with improved software (interesting part of toms hardware review: http://www.tomshardware.com/reviews/fx-8150-zambezi-bulldozer-990fx,3043-23.html) and piledriver looks quite good. Best case scenario would be 5% ipc improvement, 10% clock speed improvement, and another 15% from better optimised software. So in a best case scenario piledriver could be 25% (edit: maths fail, make that 30%) better than current bulldozer performance, worst case about 10%. Doesn't sound bad
Edit 2: the 15% best case software improvement would apply to current chips as well, so bulldozer could be a sound buy for anyone expecting to keep it for a few years or more.
Edit 3: Mollari's link below shows some tests getting a 5% or sometimes even more performance increase just from a different mobo. If I assume thats because mobo manufacturers haven't completely figured out how to get the best from bulldozer, but probably will have by the time piledriver is out (fairly big assumption I know), that bumps up the best case performance increase to 35%. Now that is definitely not bad.
I'm surprised a at the increase in gaming performance for bulldozer when it's running windows 8. Is this just because the scheduler is allowing 'turbo' to work better on lightly threaded apps?
It's partly that Windows 8 is giving different high performance tasks their own modules rather than different cores on the same module, which effectively increases the IPC. Windows 8 is also better able to combine basic tasks onto a single module, letting the CPU put more modules into lower power states and increase the turbo clock speed on the active modules. This last point also helps with power consumption.
Bulldozer isn't terrible! its just a very immature architecture, from an architectural point of view it is still a pretty decent design, performance will come to the design rather than the other way around, as applications get more threaded the attributes of the design will be shown. sure it isn't great in single threaded applications, but it was never ever going to be, that was never the point of the exercise.
honestly, all they need to do is get the 32NM process sorted out as soon as possible so the thing can run at the frequencies it was supposed to be running at (lets not forget its running slower than intended!), the temperatures will stabilise and overclocking will improve a fair amount, since in the applications its designed to do it performs well, would imagine in multi-threaded workloads it'll be untouchable in the price bracket. watch this space I would say...![]()
So when's piledriver coming then?
Having seen some of the power consumption figures for the server parts (starting at 35W, which is good even at 2.x GHz) the high power consumption, and consequently poor upper clocks, do seem to stink of problems in the manufacturing. Feels like the chips that are sent for server use are the ones that actually come out right - everything that makes it to a desktop is thus a "factory second," or at best something that fails to meet expectations
But there are still major errors in how they've marketed it... AMD are trying to sell what they hoped for instead of what they're actually making. I can't imagine pricing a Micra based on how good a 350Z is![]()
There will be some improvement, sure, but I don't really buy this argument. All the really good architectural releases were at least good right from the start.
I guess the main problem with pinning hopes on Windows scheduler enhancements pulling Bulldozer from the clutches of failure, is that these improvements will also benefit Intel CPU's to one degree or another.
Yeah maybe they should call it Drain Pipe. Far less expectations there.
